is that any way to make voice bold using audacity ?
I have worked with some of the most expensive pitch change plugins. ( recording cartoon dialogue ). Non are perfect and people are so used to hearing voices it dosnt take much effect before it sounds weird. Three things I would try simultaneously. First record with a mic with proximity effect ( bass boost when your a cuople inches from the mic) with a high sampling rate, and talk fast. Then slow down the recording, this is the best way to pitch things down and is only limited by the speed of the dialogue and the sample rate. Then you can use a pitch shift algorithm to go another 10 to 20 percent. You should be able to get close to an octave of pitch drop.
