Is it possible to make a RPTV like the Grand Wega II?
I was thinking exactly the same thing driving home tonight. I was actually not very impressed with the Grand Wega, I think there are better LCD projectors on the market. Even the geometry was a bit off, and for what they were charging for it!!
Good thought on the rear projector. Could probably find one junked real cheap. May need a conversion lens. The "lens" on the projection screen itself should allow the use of a very low lumen projector. I looked at the GWII and it only used a 100W bulb. The sales rep claimed 5,000 hour life.
Alvaius
Well lets start with the easy stuff first
-We can make the outside of the tv(the box) out of MDF. Stuff is both easy and cheap to make and work with.
-Add some casters to it like the do on the floor
-I saw once at a show a piece of glass that had a projector behind it. Had a awesome picture to it(was playing games) but it was directly behind it and the pic was only about 37in while the projector was a good 7ft away. This means that we are gonna have to figure out some sort of mirror system to this. What I know we are gonna have to do is have a mirror at the back of the tv and it should be placed at the midway of the screen. The projector is gonna need to be at the bottom.
-The optics thing is gonna be a little challenging for me as I don't have my college physics book. You want X size diagnol screen your gonna need Y size mirror and the projector is gonna have to sit z distance away from it
I think this will be a fun project to do above all else, add what you think is important
Ok I have been doing a little bit of research on this top and here is what I have found out.
The screen is a VERY soft plastic, not plexiglass or glass. Which makes sense since I have never seen a glass RPTV. It makes even more sense when you look at the high end sony 65" and see that their is actually another plastic screen over the first screen. I asked the circuit city representative told me that it is a screen saver and protects the first screen from damage
http://www.roadtoad.net/users/darius/pictures/kp-65wv700.jpg
Here is a question I posed in the avsforum
http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=215977
More on some of the research that I have been doing is that all RPTV have a depth set at 29 inches. The reason that I think this is done is that so that they can fit the tv's through doors. This might open the window for us a little bit as we could build the tv in two parts, one for the screen box and one for the projector box.
One ther problem is a e-mail that I received from ryan at diylabs
AJ,
Your design is definately possible. I have access to a different lens that would give you a much larger image per the same distance, but it is only available for order in quantities of 10, so I don't know if I could get you one (most people are wanting longer distances). It may be possible to use a double convex lens in conjuntion with the lens triplet that I am selling to effectively create a zoom lens for a larger picture. I'll have to check it out once I get my next shipment of lenses in sometime soon.
Here was the question that I posed to him
heh, bigger is better. This is kinda more research and design at this moment with more going to research. What I am trying to do is replicate what the grand wega II does. I have kinda always followed the motto if some one can build something and sell it I can always build it for cheaper. Once I found out the GW2 had a LCD in their I begun my research. I saw your design and thought that I could somehow apply it to a RPTV. The one thing that I need different is I need the shortes possible distance from the lens to the screen, kinda the opposite of what people are doing today. Just to throw another wrench in the mix I would like to do 16:9 too but I am not sure how I will do it. This tv will be hooked up to a htpc with powerstrip so i will set custom resolutions for it. That is all I have now
:idea:
Was talking about the reflective mirror thing in another thread so I thought I'd jump in here too.
I'm working on a projector project where I need front reflective mirrors too. I have an idea which I havn't put to the test yet but I have been researching.
I beleive you can use mylar film (this is an extremely metalic/polymer which comes in rolls, same stuff those shiny balloons are made of). You wrap this film around a frame and I think you can use a hair dryer to heat it and tighten it to make a very cheap, smooth reflective surface.
I had an older projection tv and they used a styrofoam type board wrapped with this mylar type film. I'm gonna try and reproduce it.
Good luck
