Is it ok to use 6SN7GT in place of 6SN7GTA/B ?
I have Darkvoice and Eufonika H5 and I am in USA (110/120V outlet). These amplifier are obviously made recently and most likely designed to take 450V 6SN7GTA/B driver tubes.
What would be the effect of using 6SN7GT tubes rated at 300V anode voltage instead of 6SN7GTA/B ? Shortened tube life, or worse, damage to the amplifiers ? I read somewhere that these are max rated limit and not the actual voltage in use.
In case it matters - I use these amplifiers not just for running headphones but also active speakers via RCA line out.
Thanks!
According to schematics of Darkvoice(-like) amplifiers that can be found on the web, B+ is only 150 V. All types of 6SN7's can cope with this easily.
That is really good to know. I ran across posts out there saying that they had no trouble using 6SN7GT with DV so this further validates that...good thing amp makers are considerate. I also own Eufonika H5 and asked its maker about this who said it is no problem at all. Hooray!
