Is a LM335 a direct replacement for a LM317T?
If the LM317 and LM338 are in the same package (TO-220), the heat dissipation capability is the same for both. To improve the power handling, add a heatsink or put a power resistor in series with the input to take up some of the wasted power. How much current do you need?
It has a large heat sink. I was able to adjust it down after changing one resistor off the LM317T divider network. Problem is as it heats up the voltage drops and I can't adjust it anymore.
I'm running separate supplies for each tube so the current should be minimal. One 9 pin 6922 style for each fil supply.
So even thought the 317T is a 1.5A and the 338 is a 5A that won't make a difference?
The 6922 only needs 0.3 Amp which is within the current rating of the LM317T. The symptoms suggest that your heatsink is completely ineffective. If that is the case, the LM338 will not work any better as it needs an effective heatsink too.
Whats the input voltage to your 317? A 5A reg in the same case wont help it still has to dissipate the same amount. A resistor in parallel accross the reg will help but it needs to be calculated carefuly. Is there no way you can drop the input voltage?
Cheers Matt.
I guess I need to figure out what size power resistor to install on the input of the supply to take the heat off the 317T.
It sounds like you have a wiring error somewhere. First off, the output voltage should not drop as the LM317 heats up. Not until it hits the thermal limit at Tj=150 C anyway. If the resistors are heating up, you're doing something wrong.
I suggest the following: Set the resistor from the output to the adjust pin to 120 ohm. Then set the resistor from adjust to ground according to the equation in the data sheet (Vout = 1.25(1+Rx/120)). You'll end up at 485 ohm for the second resistor. 470 ohm (standard value) is close enough. Vout = 1.25(1+470/120) = 6.15 V.
There will be 1.25 V across the 120 ohm resistor and negligible current flowing in the adjust pin of the LM317. Hence, approx 10 mA will flow in the two resistors. The 120 ohm resistor will dissipate about 12.5 mW (1.25 * 10E-3) and the 470 ohm resistor will dissipate 47 mW (10E-3^2 * 470). The normal 0.25 W resistor types will be just fine.
The LM317 will dissipate some amount of power. You can calculate how much if you know the current draw and the input voltage. Pdiss = (Vin-Vout)*Iout. If you dissipate more than, say, 10 W in the regulator, I'd suggest lowering the input voltage if you have that option. Otherwise, you'll need a big heat sink. Big as in several cubic inches of aluminum. A different regulator will not help you there as it'll dissipate the same amount of power and heat up to the same temperature under the same conditions.
I suggest going with the lowest input voltage you can as this dissipates the least amount of power in the LM317. However, you must have a drop of about 2.5~3 V across the regulator in order for it to work correctly. So with 6.15 V out, you need at least 9 V in.
If I interpret your first post correctly, you're applying 12 V on the input of the LM317. So the dissipated power will be on the order of 1.8 W (0.3 * (12-6.15)). You can dissipate that in one of these here heat sinks. At room temperature (~25 C), the temperature of the heat sink will be approx 40 deg C. That's slightly higher than body temperature (37 C). You should not have issues with thermal shutdown.
Hope this helps...
~Tom
I think everyone here is right. I have to drop the voltage at the input.
I measured and the PT is putting in 20VAC into the fil not the 13V that the board has imprinted. I measured .9A current draw which is bizarre give the draw of the tube is ~.3A Nothing is going to ground.
Right now I have a pair 7 ohm 10W on one fil supply and it seems stable and the 317 doesn't go much above 110ºF while the other side without the dropping resistors read 20ºF higher and starts losing voltage as it heats up.
Once I finish this circuit I need a more elegant solution so I don't have giant sandbox resistors hanging on the input - of course that probably means a new PT.
Thanks everyone.
must be syncro posting. 20V is way up there. You say 0.9A although your measurement will be influenced by charging spikes from the rectifier/cap combo.
Your on the limits of a 317, you may be able to get it down by using a smaller cap after the rectifier but its still on the border of reliability.
Is there any way you can get the input voltage down? is the secondary centre tapped?
Cheers Matt.
No center tap on the filament wires coming off the main pt. I am using a pseudo center tape at the output with the typical two 100 Ohm resisters in a voltage divider style hookup and I'm taking a ground off the point where the two meet ie teepee style.
You guys are in the UK. How's the new Dr . Who?
thats a shame, you really need to lower you input voltage. Two tubes in series using the 317 as a current reg would be good.
Yeh not seen any of the new Dr Who yet, think it starts this week. Should be good. Did you guys ever get Torchwood?
Whoops my reply disappeared.
If it shows up excuse this one. Just got back from picking up 4 10 Ohm 10W resistors which should lower the voltage to a manageable level.
I thought the UK was on the third episode by now. At least that's what the UK site says. We're about to get the first one tonight.
Watched Torchwood and liked it although they took it into a lot of strange directions. Odd to see a yank on a British site. Kind of takes the mystery away for us who live in awe of your accents. 😀
