If my goal is simply to dump the digital audio signal from my computer's CD drive into a Behringer Ultra-Drive Pro DCX-2496, is there any real justification for spending big money on a high-end sound card? For example, the inexpensive Hoontech Soundtrack SB DB III gives the Creative Soundblaster series AES/EBU I/O capability. Or I could just as easily spend 10 times the price of a Hoontech/Creative combo for a high end sound card. However, the high end sound cards are expensive in part because of their nice DAC circuits; if I'm dumping a digital signal via AES/EBU into the Behringer crossover, then all that is superfluous, right? I'd greatly appreciate some informed opinions on this subject. THANKS!
Well, I own an older SB-live and basically it more or less sucks for HQ audio. I listen to it, but the difference with my modded Philips CD-960 is *quite* large.
Problems ? Yep:
1 - JITTER
2 - My SB Live only works in 48 kHz. Yag! So everything is resampled 🙁
3 - Even the tone controls can not be turned off (bass/treble control in volume settings).
But I think there must be some cheap cards that are more acceptable! (I can't help you with that, maybe our friend Google can?)
Fedde
Problems ? Yep:
1 - JITTER
Fedde
The biggest advantage to getting a nicer sound card for digital I/O is the clocking. The Creative stuff is great for gaming and system sounds, but the internal clock is nothing to write home about. You may want to check out the Aardvark Direct Pro LX6. Aardvark is well known for making excellent digital clocks, and their Direct Pro line sounds really good. This card only has SPDIF digital I/O, but they also sell an adapter that converts SPDIF to AES/EBU.
Zach
Zach
http://www.m-audio.com/products/m-audio/dio2496.php
Choices, choices . . .
Thanks, all who have replied so far. I guess with the M-Audio Dio 2496 I would need to get a converter for AES/EBU -- such as perhaps the M-Audio CO3?
The Lynx One also has nice-looking specs, and direct support for AES/EBU.
I wonder if there is a clear hands-down winner in the range of cards with street prices under $400?
Re: Choices, choices . . .
Yes the M-Audio needs a S/PDIF <--> AES/EBU level converter. But any low-cost card with S/PDIF in/out does need that. It can handle the AES/EBU digital format. Street price around $200
I myself own an M-Audio Audiophile2496. Clock stability and jitter is pretty good. What I like also about M-Audio are the pretty good supplied drivers.
Lynx is also very good but expensive.
cards with the dirty cheap CMI8738 are sayed to be very good for S/PDIF usage, but you have to build a AES/EBU converter.... but therefore the card would cost only ~10€......
I´m very happy with my Envy24ht card from terratec..... something similar is the M-audio revolution 7.1....
the major difference between Envy24 and Envy24HT is that the HT has no hardware mixer..... but you had to pay to much for that imho.... I think you can get such a card for ~80€
You could also surf to Rightmark.org and ask there.
http://forum.rightmark.org/cgi-bin/Ultimate.cgi
Rightmark has loads of test resutls of sound cards, tested with their free(!) excellent software.... but beware: they are russians!
Test results
http://audio.rightmark.org/results.html
Test results
You should be able to get a Lynx One for right around $400, if not less, since the MSRP is $500, and most people are going with the 2 or L22... It is a perfect device for the application you need. It supports the format you need via ballanced interconnects. More importantly, it has a top notch clock, and you will not have to worry about jitter at all! If you even feel like using the onboard DAC, you are not compromizing one bit!!! (no pun intended) You get awsome flexibility, and build quality. With a PC, you already have to worry about so much interference, so why have a headache with the interface? Lynx all the way man.
Thanks, I ultimately went with the LynxTwo myself, when I realized I could (through the right software) get it to function as a digital crossover, manipulating both the frequency and the time domains. Eventually I'll try using it for digital room correction as well.
cdwitmer,
What software are you using? I've been looking for a way to use my computer as a digital crossover, EQ and room correction engine for a couple of years now, but haven't found anything suitable.
I recently bought a LynxTwo, as well.
Thanks.
Brad
Thanks.
Brad
Brad,
SoundEasy seems to be the software with the most promise for DXO, DRC, DEQ, etc., whilst not blasting my budget into orbit. The learning curve is pretty steep, apparently. (I haven't actually obtained or used it yet. In the meantime I'm using an analog active crossover.)
Besides this message board, various Yahoo! egroups can be useful, such as SoundEasyuserslist. Other Yahoo! groups include hifi_dsp, PAMS, LynxONE, and TacTAudioUsersGroup.
Chris
Chris
cdwitmer said:Thanks, all who have replied so far. I guess with the M-Audio Dio 2496 I would need to get a converter for AES/EBU -- such as perhaps the M-Audio CO3?
You can use a Neutrik SPDIF to AES/EBU in line transformer; no power needed ans sounds fine - about £17.
- Digital Source
- Is a *CHEAP* AES/EBU sound card going to be adequate?
