The case styles are different. The 778 is rated for more current.
HTTP 301 This page has been moved
Finding either of these that are not counterfeit may be difficult.
The following transistor datasheet lists transistors that are readily available and in various case styles. This is the NPN version but the PNP versions (like the ones you listed) are listed as well.
http://datasheet.octopart.com/FJA4313OTU-Fairchild-Semiconductor-datasheet-8332429.pdf
