Hi
I have mTX amplifier with outputs IRL540N. The amp is 4 channel. Can I replace one channel with IRF540N instead IRL540N?
Probably not.
The L is a logic level part.
If it does work, the bias will have to be set very low. The amp may not have enough range in the bias circuit.
