I have designed and built the IRF511 Mosfet SRPP amplifier. It is so simple, contains a few components, easy to built, powerful and gives tube like sound. 🙂
IRF511 is very interesting mosfet. Input capacitance value is very low: (135pf only)
It is very fast: Turn-on delay time is 8ns, rise time is 25ns, turn-off delay time is 15ns, fall time is 12ns.
You must arrange the current with 100K stereo pot around 1.3-1.6 Amp.
Nice circuit, Noyan.
What sort of gain and frequency response? It seems to quite a bit of local feedback.
Ciao,
Hugh
Ciao,
Hugh
Hi Aksa,
Actually i have not measured it yet. But, i can say it's gain is quite much and was enough to drive my Tannoy Saturn S10 loudspeakers directly without preamplifier. About the local feedback, this is original SRPP design 🙂 SRPP design known with it's clean, open sound.
Noyan
Noyan
I had presented an hybrid variant here: http://www.diyaudio.com/forums/solid-state/228913-two-transistor-push-pull-ab-amplifier.html
In the spec page, max. dissipation of the IRF511 given as 43W. On my amp schematic each IRF511 takes 12V*1,5A=18W load. I am not sure that what if i push each of them till for example around 35W dissipation. Any comment? 😕
Meanwhile, how can i calculate or measure the real output of my ampifier? 😕
Noyan
43W is at 25C. Depending on your heatsink size they could be running as hot as 100C, Bringing their max dissipation down to ~21W. I wouldn't push them much further.
Thank you!
Noyan
Power MOSfets are cheap, simply buy a 250W part and you get peace of mind, provided your heatsink is big enoughIn the spec page, max. dissipation of the IRF511 given as 43W. On my amp schematic each IRF511 takes 12V*1,5A=18W load. I am not sure that what if i push each of them till for example around 35W dissipation. Any comment? 😕
The theoretical peak current should be ~twice the quiescent current, that is 2A rms, thus 32W on 8 ohm ignoring the supply voltage and many other factors. With a real SRPP, you are lucky if you manage to arrive at 10WMeanwhile, how can i calculate
Measure the rms output voltage on a load, then P=Vrms²/Zload
Many thanks for your explanations 🙂
Why i am using IRF511, because it's input capacitance is very lower than the other mosfets. Also, it is looking faster to me. I thought that these parameters are important for better sound quality. Or, may be i am wrong??? 😕
Input capacitance: 135pf
It is true that with this kind of circuit, the capacitance will be multiplied by Miller effect, and even a modest device like the the 511 will present a challenging load to the preamplifier. But that is the price to be paid for such a minimalist circuit.Why i am using IRF511, because it's input capacitance is very lower than the other mosfets. Also, it is looking faster to me. I thought that these parameters are important for better sound quality. Or, may be i am wrong??? 😕
The switching times are unimportant for linear applications, and the time constants of a big device are not very different from that of a smaller one
Hi, Noyan
You could try some RF LDMOS, BLF861A is around Rp.600rb in my country local shop. 318W, 200deg Tj, each MOS and it contains 2 MOS per package (stereo). Use hexfet for ccs
I checked it and noticed that, it does not fit to my schematic. It contains two mosfets in one package but their source pins are common. So, I should use two devices (packages) for each channel. It will be too costly for me and unnecessarily very powerful as well.
Yes it is a bit overpriced in western shop, and blf861A isn't better than $100 MRF6VP100H.
CCS is still using hexfet.
Some plastic package are single and cheaper like this one:
MRF9045N $24 from mouser.
http://www.mouser.com/ds/2/161/MRF9045N-256348.pdf
170W, 200C Tj, 65V, 70pf Ciss
Anyway it will still costly compared to 510. You could double it (all) including the speaker for louder / higher power
- IRF511 Simple SRPP mosfet amplifier circuit
