Dear Friends,
A friend of mine brought an ION Obelist 100 amp to help him solve the problem. The amp is working fine. When you press the "listen: switch each time, it is suppose to select a different input. The problem is, at times when you press the "listen" switch, it does not change input at all and at times it changes input automatically by itself. The input keeps toggling by itself without pressing any button. Can someone kindly assist me. What can be causing this problem?.
Thank you
Carlos
Thank you
Carlos
