Inverting Subs - Worth It for Cooling?
Hi, all...
I think I have a full picture of all the advantages/disadvantages of standard versus inverted mounting, but I've never found a satisfactory answer to this question:
All things being equal on a sealed box, do you think it's worth inverting the subs solely for the benefit of keeping the voice-coil/motor cooler?
I mean... it's has to get hot in that sealed chamber, right? I know it varies based on the size of the subwoofer and the size of the chamber, but how hot does it get in there? Does it approach a level where it really 'matters'?
An experience that makes me ask: I had a 4th-order bandpass enclosure for four subs, all of which were individually chambered (to the same specs). Two of them were mounted in the standard cone-out fashion, and two of them were inverted. Well, guess what? When I took the woofers out of the box, two of them had seized (the standard mount) and two of them were fine (the inverted mount). It could be a coincidence, but I can't help but wonder as I build my next sealed box.
I would appreciate any insights you might have. Thanks!
Ok, Perry... cool. No, I'm running them well below rated power, so I'm not worried about that.
I modeled that old bandpass enclosure on WinISD, and I think those woofers probably suffered from over-excursion, too.
Thanks for chiming in!
Unnecessary,even in Texas.
But if your enclosure is wayyy too small, every cubic inch helps.
If you like to look at a cool motor, though, remember it might look cool to a thief, too.
Hey, boswald... that made me laugh twice. Each sub will be in just over 2 ft^3, so they have some breathing room.
In my opinion, these are very attractive subwoofers--both the cones and the magnets. I think I like the cones better, though, so it's nice to know that probably won't harm anything.
Thanks!
A LOT of people refuse to believe that they run their amps into clipping. An easy way to find out is to use an oscilloscope to watch the output signals. The DSO138 from ebay (assembled, not a kit), is cheap enough for most people. When you get your next system installed, watch the output.
You will also need one of the $5 100mhz scope probes that are all over ebay to extend the voltage range of the scope.
I'm not recommending these scopes for anything other than watching for clipping. They are useless for any square wave over about 1kHz.
When clipped, the amplifier can drive more power to the coils with less amplitude (and less cone excursion) than it would with a clean signal.
If you do this, you can use a rotary switch to switch between front/rear/sub channels. If you use a rotary switch it MUST be a break-BEFORE-make switch. If the switch doesn't break between positions, it will short channels together.
