Inverter for Turntable PSU ?
This may be a silly question, but would it be possible or feasible to use an inverter that converts 12 volts dc to 120 or 240 volts ac to power a turntable synchronous motor ? Some are listed as producing a pure sine wave as opposed to a modified sine wave.
Ralph-
Be aware that the EGS002 is not analog output, it is PWM. It is designed to drive a HV SMPS output stage. If implemented correctly, you could create 115/230VAC 50/60Hz without a step up transformer, but it would require a decent output filter as well to reduce EMI.
It is most definitely digital output (PWM), but an unusual configuration. The upper bridge is the PWM sinewave with both halves centered and the bottom bridge shifts the reference point (neutral line) at the line frequency. The output filter is L1 & C22 on the output amp section and is only necessary on the high frequency PWM bridge that produces the AC waveform.
