Hi,,
I've been thinking of building a small horn lately with a 6,5 or 8 inch driver but whatnt/s parameters should a driver suited for a horn have?
And secondly, how do I go about building one?
I have nice 8" drivers that are really cheap but still has 12mm Xmax.
The driver is Omnes audio W8-670Z but I don't know if it is a suitable driver for a horn.
What parameters should a driver suitable for a horn have? Please list some guidelines for me so I know what to look for in a driver sjifed for a small 6,t or 8 inch horn.
It would be helpful if someone listed for example suitable Qts, Vas, Fs, and such that would be useful in a horn.
After finding a nice driver comes next problem which is even bigger, how the f**k do I design a good horn?
I KNOW hornresp is available but it seems like mathematics on Arabic for me, not easy to understand.
Please help me Out fellow diy'ers
Thanks in advance!! //JK
Basically drivers with low qts, high BL and high xmax. you can then compare drivers strongness with the math BL^2/Re. And of course compare them inside HR.
your driver can work in a horn, but there are better drivers out there, for example the TB W8-740P, TB W8-1363SB, Dayton RSS210HO*4, to name a few.
But a small horn with a small sub is not going to do much, better small alternatives are sealed or ported or sealed with passive radiators.
Some topics on 8" horns:
dual 8" spud
anarchy horn
Visaton 8 horn
high output 8 tapped horn
dual 8" spud
anarchy horn
Visaton 8 horn
