i'm hooking up a miniref amp (linuxguru design) to function as both poweramp and an integrate with 1 set of rca straight to the amp and the other set for going through volume pot.
the amp has a floating ground so with nothing connected the amp hums.
can i wire both the volume pot and bare rca to the same input without any issue? if not, can a toggle switch be utilized, and how?
