Installing a sound system in a tanning salon
Can someone recommend the most economical way to build out a sound system in a 27 room tanning salon with the following parameters:
(1) Each room would have a 4 position switch to select from 4 different radio stations or input sources.
(2) Each room would have a volume control.
Currently all rooms have been wired "home run" with 8 wires. I was told this gives you the most flexibility.
Thanks in advance,
Bob
