input on led
The first link definately no. 10,000mcd is nothing. I have a single LED capable of 120,000mcd, and I'm going to use nearly 200 of those to make a clear screen. I currently have 100 of those, and can see the screen, but any room lighting totally kills the picture.
The second link is better, but still nowhere near what you need. Just think of a 40 watt lightbulb. (360* output compared to LED 180* and less heat loss.) There's no way a 40 watt bulb would be bright enough for a DIY projector.
Here's the LEDs that I am using 180-200 of:
http://www.lck-led.com/product_info.php?products_id=162
Also can be found on ebay.
The last link that you gave me looks about right.
I'll try to give you a lot of information on the LEDs, but you might get confused as well.
The LEDs that I am using are 10mm, but have 4l ight emmiting sources in each LED. Think of a light bulb with 4 filaments in it. 4 at 30,000mcd = my 120,000mcd. Mine are rated between 60-80 milliamps.
These that you posted are 10mm, 130,000mcd, and appear to have only one source per LED, and run at 20-30 milliamps.
The milliamps per LED and the way you wire them will determine how many resistors you will need. Yours come with a 510ohm resistor for each LED so you would need to wire each led in parallel to a resistor:
+ is positive wire
? is resistor
@ is LED
| is negative side of LED
- is negative wire (ground)
. is nothing
This setup will not work with your wall socket voltage (110AC). You will have to find a suitable power supply that is 12-13.5volts and about 10 amps.
The circuit board needs to be the size of your screen minus a few centimeters. You want to end up with a pattern where there is an LED every 3 or less centimeters:
X..X..X..X..X..X..X..X..X..X..X
..X..X..X..X..X..X..X..X..X..X..
They will all have to be aimed squarely at the monitor from 12-18 inches depending on your lenses. I used 11 by 9 originally, and am waiting for more LEDs to come so I can add in the rows that starts off like ..X
Use:
LED Board---->LCD Screen----->Fresnel------->Exit lense
There is no need for the other fresnel.
+ is positive wire
? is resistor
@ is LED
. is nothing
[/B]
Do you have to have a resistor with each LED or could you put a bigger resistor at the beginning of each row of led’s?
Zaner21
