It's not too often I see a design and think that it's innovative but I just saw a speaker here (look for the Trapezoid) that got my interest.
I use an open baffle with TL bass myself but the TL subs are much larger. I wondered how they can get bass down to 25 Hz from a 12 inch (30 cm) diameter tube just 33 inches (85 cm) high?
If this works then I'll be after some Sonotubes myself! 😉
Nuuk,
It doesn't say flat to 25hz, just down to 25hz. The TL using a 33"L by 12" dia pvc pipe seems like a single fold TL to me. With a 24"W x 20"D footprint I think it would be easy to go fully dipole with larger driver(s) or use a U baffle for the bass and exceed the performance they claim in a much nicer looking package and a smaller footprint.
Yes, I suppose if I want to be rid of my TL 'monsters' there are other solutions like the U baffle woofers or even a W baffle. I was just interested in the TL solution as it was more compact than mine.
I also thought it quite a large baffe if it only has to go down to 150 Hz!
I also thought it quite a large baffe if it only has to go down to 150 Hz!![]()
It seems that the baffle's primary purpose is to hide the 12" diameter PVC pipe in the back. You could use the same drivers and fit a boxed TL in a much more compact form. I'd rather see the woofer on the front to break up the look of that wall of a baffle unless having it up firing serves some benefit.
I didn't manage it! 🙁 But I did have my bass driver firing through the main baffle and the aperture actually improved the look of the baffle! 🙂
Nuuk said:I didn't manage it! 🙁 But I did have my bass driver firing through the main baffle and the aperture actually improved the look of the baffle! 🙂
I bet yours produces a lot more bass than their little 10" in a short line.
Nuuk said:I also thought it quite a large baffe if it only has to go down to 150 Hz!![]()
150?
They say 250hz, but that's with the third-order crossover.
audiobomber said:What coincident driver do they use in the Trapezoid?
By the looks it's a Seas coax.
- Innovative OB/TL design
