Hello there!
I was wondering, and after searching the web through various search engines, if anybody knows the pinout of this chip, especially the I2S pins, and the SAA7349, both surface mount.
Thanks!
Thanks!
the only source where this type is mentioned is the application note by page 10 in the Daisylaser datasheet of the RF buffer TZA1022 (TZA1022 used on the laser head from VAM1254 and VAL1250).
Also the same type with suffix HL (SAA7359HL) is helpful by google.
Even about internal NXP search engine I will find any information.
Either it is a custom made version for IDE drive or a mißprint in that datasheet.
http://www.daisy-laser.com/products/cd/modules/cdpro2/TZA1022datasheet.pdf
"Alldatasheet" listed follow types about SAA73**
SAA7310 CMOS decoder for compact disc systems
SAA7310GP CMOS decoder for compact disc systems 52
SAA7310P CMOS decoder for compact disc systems 51
SAA7324 Digital servo processor and Compact Disc decoder with integrated DAC CD10 II 50
SAA7324H Digital servo processor and Compact Disc decoder with integrated DAC CD10 II 49
SAA7325 Digital servo processor and Compact Disc decoder with integrated DAC CD10 48
SAA7325H Digital servo processor and Compact Disc decoder with integrated DAC CD10 47
SAA7326 Digital servo processor and Compact Disc decoder with integrated DAC CD10 46
SAA7326H Digital servo processor and Compact Disc decoder with integrated DAC CD10 45
SAA7327 Digital servo processor and Compact Disc decoder with integrated DAC for video CD CD7 II 44
SAA7327H Digital servo processor and Compact Disc decoder with integrated DAC for video CD CD7 II 43
SAA7335 DSP for CD and DVD-ROM systems 42
SAA7335GP DSP for CD and DVD-ROM systems 41
SAA7341 COMS Digital decoding IC for Compact Disc 40
SAA7341GP COMS Digital decoding IC for Compact Disc 39
SAA7345 CMOS digital decoding IC with RAM for Compact Disc 38
SAA7345GP CMOS digital decoding IC with RAM for Compact Disc 37
SAA7346 Shock absorbing RAM addresser 36
SAA7346H Shock absorbing RAM addresser 35
SAA7348GP All Compact Disc Engine ACE 34
SAA7356HL 1394 SBP-2 link layer controller 33
SAA7360 Bitstream conversion ADC for digital audio systems 32
SAA7360GP Bitstream conversion ADC for digital audio systems 31
SAA7366 Bitstream conversion ADC for digital audio systems 30
SAA7366T Bitstream conversion ADC for digital audio systems 29
SAA7367 Bitstream conversion ADC for digital audio systems 28
SAA7370 Digital servo processor and Compact Disc decoder CD7 27
SAA7370A Digital servo processor and Compact Disc decoder CD7 26
SAA7371 Digital servo processor and Compact Disc decoder CD7 25
SAA7371GP Digital servo processor and Compact Disc decoder CD7 24
SAA7372 Digital servo processor and Compact Disc decoder CD7 NXP Semiconductors 23
SAA7373 Digital servo processor and Compact Disc decoder CD7 22
SAA7373GP Digital servo processor and Compact Disc decoder CD7 21
SAA7374 Low voltage digital servo processor and Compact Disc decoder CD7LV 20
SAA7374GP Low voltage digital servo processor and Compact Disc decoder CD7LV 19
SAA7376 Digital servo processor and Compact Disc decoder CD7 18
SAA7377 Digital servo processor and Compact Disc decoder CD7 17
SAA7377GP Digital servo processor and Compact Disc decoder CD7 16
SAA7378GP Single Chip Digital Servo Processor and Compact Disc Decoder 15
SAA7380 Error correction and host interface IC for CD-ROM ELM 14
SAA7380GP Error correction and host interface IC for CD-ROM ELM 13
SAA7381 ATAPI CD-R block decoder 12
SAA7382 Error correction and host interface IC for CD-ROM ELM 11
SAA7382GP Error correction and host interface IC for CD-ROM ELM 10
SAA7385 Error correction and host interface IC for CD-ROM SEQUOIA 9
SAA7385GP Error correction and host interface IC for CD-ROM SEQUOIA 8
SAA7388 Error correction and host interface IC for CD-ROM ELM 7
SAA7388GP Error correction and host interface IC for CD-ROM ELM 6
SAA7390 High performance Compact Disc-Recordable CD-R controller 5
SAA7390GP High performance Compact Disc-Recordable CD-R controller 4
SAA7391 ATAPI CD-R block encoder/decoder 3
SAA7391H ATAPI CD-R block encoder/decoder 2
SAA7392 Channel encoder/decoder CDR60 1
SAA7392HL Channel encoder/decoder CDR60
