Infinte baffle characteristic?
I've found the following characterizes a good infinite baffle:
*strong such that vibrations and resonance are minimized
*separates the front wave from the rear wave very well; no leaks
*arranges the speakers dual opposed; force cancelling design
Efficiency will depend on the frequency in question and how much cancellation exists around the baffle. Typically, IB is more efficient than sealed but less efficient than a ported box.
Perhaps as good an answer as any would be another question - what is your intended application?
As with numerous other technically excellent topologies, the "where" and "how" the system will be used must be included in the design calculus.
hypothetical driver
Fs 20 Hz
Qts 0.405
Qes 0.45
Vas 100 Liters
Re 2.7 ohms
case 1 is infinite baffle
case 2 is a 40liter sealed box
case 3 is a 100 liter vented box tuned to 20Hz
All produce the same midband SPL - 89dB at 2.83 volts
I thought that an IB driver had to have a higher Qts. Something around .8 to 1.2
If you have any way to EQ the signal then it is much better with a much stronger low Q driver. You need a lot of voltage-swing but not a lot of current if you use high efficiency pro drivers. B&C 15TBX100 is a good OB driver for bass duty. You can get great efficiency from OBs. It is as usual a large radiating surface, low moving mass and lots of BL (motor strength) that will create efficiency.
Johannes
