Infinity 7541a problems please help
Alright guys here's my issue. I installed the amp and have everything run correctly. I turn on my car and the amps protect light comes on and then fades out after about five seconds and nothing else happens. I am getting 12.5 amps to the amp and the ground is valid. The fuses are also fine. What could potentially be wrong???
Bruce
You need to measure the DC voltage directly across the screw terminals on the amp. Monitor the voltage from just before remote voltage is applied and the time that the protect LED is illuminated. Does the voltage ever drop to below 12v?
The output transistors could be shorted but you need to confirm that you have good power connections (as described above) before you do anything else.
