Inductors for TAS5630 in INDIA
Hi
Anyone has information from where i can get the inductors in INDIA with the good similar specs from TI.
detailed spec pdf is attached.
DWG no.: TIC-INDC-026(1.00)
Text: 7μH / 5A / 30mΩ
Diagram:
Material: Core: Micrometals T94-2
Wire: ø1.00mm Cu, one layer lacquer, 155°C
Lead length: 8mm-12mm, stripped and pre-tinned.
Production: Step 1: N1, 29 turns ø1.00mm cu 2L, start 1, end 2
Step 2: bend and strip/pre-tin leads.
Test: Inductance: pin 1 –2 6 – 8 μH @ 0.1Vrms/10kHz
