Inductor value
Hi everybody.
I have an iron core inductor that currently has a value of 1.8 mh.
I need to change it to 3 mh. The supplier has none in stock and the part would be back ordered til who knows when.
Would it be possible to change the value of this by adding windings or would I be better off to buy another?
I have a DATS v3, so I can test and fine tune.
If this is something anybody has done please tell me what and how.
Thanks!
GordB,
it would neither be smart to buy a new larger inductance coil nor add another in series with this one. Just solder some magnet wire to your current inductor and constantly check its inductance, once you have it, cut the rest and finish it. Space you've got plenty.
According to my calculations, you'd need about 3.7 m of magnet wire to make it become 3mH.
Killer. I've ordered a 4 oz spool which is almost 10m. Should be good.
Now, does the joint between the existing and new magnet wire, once soldered, need to be insulated? And could a guy use something like nail polish for the insulation or just use shrink tubing?
It does not need to be, but you could if you felt up for it. I never did. If it measures the right mH, it is fine, and if something went wrong, you'd measure it as such. Make the soldered spot nice and well done and you will be alright. A couple of mm of overlap should suffice.
The joint is probably going to be fat and have sharp edges. I would use lengthwise twisting (before soldering) and heatshrink to prevent damaging other insulation, and preferrably have it off to one end.
Thanks Allen.
I'll see if I can make that happen. It looks like the core, which is rectangular, is about 31 mm on a side, and 40 or so on the other. I'll try to get it lined up on the longer of the two.
