InDIYana 2023 speaker DIY event...
Dear Mr Wolf: question about this rule (and any related):
no large waveguides allowed, see faceplate rule. No large coaxial waveguides either, must be behind dustcaps if coaxial. Can only use waveguide if stock and fits within size criteria. If using a compression driver magnet must not exceed >5" diameter, and horn must comply with face sizes.
Would a a 12" coaxial driver with its CD tweeter would be acceptable under the rules? Isn't that a "large waveguide"??? Or are you not allowing those wierd "coax" drivers that have a separate waveguide sticking out from the woofer center?
I just happen to have a pair of the traditional type of 12" coax drivers and some CDs lying around that I might try to put into play, if allowed.
Reactions: NeonDriver
