Well after adding 10 CM of 7CM diameter drainpipe into my now ported subwoofer enclosure, all I can say is damn! The difference is incredible, stunning and well worth all the effort!
I played bits of the SW Episode 2 DVD with my dad in the room and he said himself that the difference was substantial...You can feel it in your stomach. You can also feel the air from the port half way across the room! 😉
Here's a photo of the sub (you can't see the port) for those who haven't yet seen it:
It's a 12" car driver, and I can immediately notice less distortion and less excursion to reach deeper levels. It's most likely due to the fact that there's an air intake and not a "vacuum" inside the box, which I heard was bad for some drivers.
I'm only feeding it with a 100Watt Technics amp, and it goes to impressive levels!
When purchasing the drain pipe (we had to buy two metres just for 10 CM!!
)we also found some draught excluder for sealing the driver, the bottom of the cage doesn't act like a port now!!
So here it is, my £30 DIY subwoofer that sounds like a £300 one!
I couldn't have done much of it without the help of you guys, so a big thank you to all of you!! 🙂
Any questions or comments, don't hesitate to ask!!
Howard
Howard
Congratulations. Nicely done. Had you included the construction of this--and the problems you were having--in another thread? I'd love to read what you read.
Dave
Dave
Sure. Here are some threads I posted relating to my sub:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=18967
http://www.diyaudio.com/forums/showthread.php?s=&threadid=18851
http://www.diyaudio.com/forums/showthread.php?s=&threadid=17984
http://www.diyaudio.com/forums/showthread.php?s=&threadid=17914
Glad to see it worked out so well.
We figured that if it worked-great. If it doesn't-just plug the port and chalk it up to experience.
Nothing ventured, nothing gained. You gambled and won.
Remember, you were the one who came up with the idea in the first place-we just helped you to execute it. Congratulations.
really cool
Thats a really cool shape! It gave me an idea, I'm doing a 1-1.5 ft^3 box for a titanic mkII(basically this thing will cost me a whole month's paycheck), and a 250 watt plate amp. I'm going to have the amp all recessed into the box by cutting a underhand into it, kindof like a cave the amp will fit into, so I could put a door over the amp and it would still be a hexagon (not that I'd do that).
Did you have any troule at all getting everything lined up?
I didn't build the basic box
I bought it and the driver off eBay, but the box was quite badly finished so we spent a weekend making it nice and sealing gaps, etc 🙂
I can't find the edit command...Either it's gone or I'm blind!
Anyway to add to my above comment, the side panels were stuck together very well and braced in the corners for strength. The top and bottom panels weren't so well done. We had to fill in some gaps at the bottom so everything was sealed. We then ran a tube of silicone sealant around every inside edge, used filler to hide screw holes, and draught excluder to seal the sub. The terminal box had a seal already so we didn't need to alter that. We smeared a small amount of silicone sealant around the outside edge of the port (It fits so tight however that the drainpipe moulded to the slightly irregular round shape!) just so ensure nothing leaks where it shouldn't!
I'm proud of this. It may not sound as good as the subs you guys spend months working on, but it sounds brilliant to me, and it'll be providing the low frequencies in my home cinema for quite a few years I presume!
.....but it sounds brilliant to me, and it'll be providing the low frequencies in my home cinema for quite a few years I presume!
Haha...just wait till your looking through the next speaker catalog and see that "great" deal....or if you keep hanging out on this forum.
This hobby is like any other, you'll always want to keep "upgrading"
- Incredible
