Increasing throw from short horn
Hi guys, this wide dispersion short throw horn here:
Selenium HC23-25 1" Exponential Horn 100x40 1-3/8"-18 TPI
or
(same horn)
If I had a machinist make a short 2-4" extention at the throat, would it increase the projection? (throw) even if the very wide 100 deg was reduced a bit as a result?
This is for an emergency PA type - not concerned about fidelity.
Hope someone's tried this before!
Well thanks - but is that the result of any lack of taper?
TOA make a (long) long throw horn with a very gentle taper before the more abrupt mouth opening flare.
That's why I am surprised there would be NO improvement in distance with a straight extention. Is there a minimum length necessary for this?
Also I asked if there would be any detriment. If not, it may simply make construction easier.
