Increase resistors wattages by combining them ...any reason why not to? (tube amps)
some resistors in tube amplifiers need to be able to handle some higher wattages, as you know. Is there any reason, why I shouldn't combine resistors to increase their max. power values? Or doesn't this create any difference or dangers and I don't have to buy the whole range of high power resistors of any value to be able to experiment at home without waiting for ordered parts all the time?
Thank you!
poppy
As far as i know, you‘re good with it, except that you‘ll be using more parts, more space and a good calculator...
Diyaudiostore‘s universal PSU works this way and is recommended for Nelson‘s treasures, so: 🙂
Thank you!
poppy
Do you know how to calculate the equivalent resistance from putting two or more in series or parallel? And how to calculate the equivalent power handling when the resistors are not equal?
Jan
Early solid state Television power supplies used a 270R 1W resistor from the 340volt HT to start the power supply oscillator. They used to use a 150k and 120k in series. Both rated at 1/2W and the higher valued resistor used to fail first because the inadequate wattage of the 150k resistor.
Be careful when deciding specific values.
Resistors in parallel just add the power ratings but resistors in series be cautious. The higher value resistor dissipates more power than the lower value. (Kirchoffs law) Isaac Physics
In parallel, they also won't dissipate evenly unless they're the same value. The smaller value in this case will dissipate more as it will carry more of the current.
