I Bit the bullet and had some Snap In caps made for me, couldn't find them surplus so they are marked AJ (APEX JR) as the manufacturer, these are new stock.
15,000 Uf 63V at 105 degrees and measure 35MM X 70MM
1 3/8 Dia X 2 3/4" Tall
Price is $6.59ea 10 for $62.50
Price is $6.59ea
Hi Steve,
Do you have specs?
Yes, and post more after I get back from vacation and listed on the website.
Capacitance tolerance at 20C, 120Hz 20%
Load life of 2000 hr at 105C
Having Safety Vents
Wide temperature range
Leakage current at 20C
(After 1 minute application of rated voltage
1<0.02CV or 5Ma, whichever is smaller
Where C: Normal capacitance in Uf, V: Rated voltage in V
Dissipation Factor (Tan8) At 20C ,120Hz .15
For capacitance of more than 1000 add .02 for every increase of 1000Uf
Load Life: The following spec's shall be satified when the capacitors are restored to the 20C after the rated voltage has been applied for 2,000 hr
at 105C
Capacitance change < 20% of the initial value
Tan8 <200% of the initial specified value
I The initial value
Shelf life:
The following Spec's shall be satisfied when the capacitors are restored
to 20C after exposing them at 105C for 1000 Hrs without voltage applied
Tan8 < 150% of the initial specified value
I < 200% of the initial specified value
Satisfies characteristic W of JIS C5141
Having Safety Vents
at 105C
I The initial value
Shelf life:
Made by Xicon?
NOPE.... These are made by TopMay along with some of my axial
450V electolytics ....These are better than the Xicons
AndrewGM....
I will be back March 5th and will PM you before.
- More Vendors...
- Apex Jr
- IN STOCK... 15,000UF 63V Snap In
