IN SEARCH OF "GENUINE" TOSHIBA 2SC5200
I need a few 100% genuine Toshiba 2SC5200 transistors, in a TO-264 package (same as/similar to TO-3PL)
It will be replacing a failed Toshiba , Japan, 2SC5200, lot number 831, from around 10 years ago * See photo
Toshiba has a newer unit, different specs, in a smaller TO-3P ( aka TO-3P-3) package. I believe that it is not the same device and not a good match for the original. ( I prefer to use the original complimentary 2SA1943 that is installed currently)
It is not clear that even the large distributors can supply genuine and original Toshiba devices.
The level of counterfeit with this item is, I'm told, very high.
If you have some, please PM me.
Much thanks
SW 🙂
Much thanks
SW 🙂
