Importing Tweeters Or Mids Into LspCAD for Adire?
diyAudio Moderator Emeritus
Joined 2001
I wonder is anyone knows how to import nonAdire mids and tweeters into LspCAD for Adire.
In fact, I wonder is you can show how a Shiva might cross into an AV 8. As far as I can see, this version seems capable of displaying only one driver at a time. Is that true?
Im sure there must be some way around the demo versions of LSPcad to give the user the ability to use drivers other then the ones supplied with the program. I had a demo of one version and it had a coupla woofs and tweets with the demo. It wouldnt open anything but these example files. I also opened the files up and altered the parameters, it program even detected this, even though the files were the same and shut its self down. Ingemar has a very sucessful anti no ppl purchase program applied to the demos, which make it very hard to abuse it.
I have no problems as I have LSPcad Pro now but I think your gonna be fighting a loosing battle.
Fifth Element:
Actually, I was not so much interested in getting around the fact that the program is designed only for Adire drivers. It is just that as long as they have the software to design a crossover, I wondered if they had a provision to import a suitable driver to crossover into. I have no problem limiting the woofer to Adire woofers, I just wondered why bother allowing a filter section if you are not going to allow the higher frequency driver to be displayed in the program.
For instance, they will let you design a filter to cross the AV 8 over at 500 Hz-but no provision to import into the program a suitable driver for the AV 8 to crossover into. I've never heard of anybody designing crossovers by using one program to design the lower half and a different program to design the upper half.
Has anyone else? :xeye:
