The new editor has keyboard shortcuts, one member noted CTRL-P is usually print screen but here it inserts an image.
A range of standard shortcuts can be agreed on in this thread and then implemented.
Ctrl-P usually opens the Print dialog. (IBM-heritage machines have a PrnScr key.) (Apple has Shift + Command + 3 to print screen.)CTRL-P is usually print screen but here it inserts an image.
Here/now Ctrl-P generally starts Print dialog, but IN the message composition box it invites an image-drop. I'm not seeing a need to start a print INside the message composition box? If I suddenly need to, clicking outside the compose box restores standard context.
Unexpected but not wrong. 🤔
