Impedence Compensation Experiences
I have recently setup a test jig so that I can impedence sweep loudspeakers, and apply both RC compensation, and series RLC driver resonance and confirm the results.
I am finding the results to extremely worthwhile the effort on the tweeters of my old (ca1977) KEF 8" 2ways.
Sonic results are dramatically cleaner mids and highs, and extension of highs.
Instrument timbres and vocal timbres are much more accurate than before - I know the live performance and conversation spoken voices of some of the musos on my test records.
Anybody have similar experiences and results ?.
And what soundcard software are you using ?.
Eric.
Hi Remy,
Yes I am talking about series LCR shunt network to cancel the mechanical resonance impedence peak, and also shunt RC network to cancel the inductive rising impedence characteristic, as discussed in the 'zobel.pdf' link that you give.
I had not considered that the RC network should be four components - thanks for the link.
I am getting a fairly close to flat impedence characteristic for the tweeter, and this is removes audible tweeter resonance effects very effectively.
Have you explored this /.
Eric.
It´s a Bandaid. If you´re really doing a crossover optimization (and assuming you have a low-Z output amp), the parallel network may or may not prove useful. It´s most useful in cases where someone can measure Z, but doesn´t want to do anything with xover optimization and is trying a textbook xover. Real Men use target functions appropriate for the driver/geometry/polar pattern and use whatever topology it takes to hit them.
Polishing Turds.....
Hi Sy,
My purpose here is to improve existing speakers without major rework.
In this case, the result is very nicely successful, for minimum cost and time.
In this case I am sweeping the driver to determine its impedence characteristic, applying the networks and confirming the combined impedence curve - the result is measuring close to flat.
The sonic result of this is dramatically lowered overtones and hash from the tweeter.
Can you elaborate some on the 'real men' bit ?.
Eric.
If you´re just adding them to an existing design, you´ll noticeably change the frequency response. Whether that´s a good thing or a bad thing is a random event, depending on the initial design of the speaker (if you did this to the woofer of of an NHT Super Zero, you´d definitely make the response more colored) and what you think is "better" (a lot of people really like really colored speakers).
Generalizing from the particular is a classic error. That´s the origin of the "real men" comment.
are you sure that zobels and RLCs change the frequency response?
I've been told that, since they are in parallel with the speaker, they both see the same voltage, so the frequency response is unchanged
the only thing that changes is the current drawn from the impedance compensation network, to maintain the total drawn current constant over the whole frequency range-> the amp sees a resistive load, and is happier 🙂
Rather Good Now.
Bricolo said:
eric: what is the crossover design you're optimising?
I mean, the crossover before any modification
I have not bothered to draw the schematic, but on first inspection looks like 12dB with impedence comp across the woofer.
I have added impedence comp and resonance comp across the tweeter.
FR is not particularly changed, but resonance behaviour of the tweeter is very noticeably changed.
Hard essing on vocals and cymbals is gone, and highs are much clearer and cleaner.
This KEF speaker is a 25yo design, and these tweeters have never been wonderful, but this mod improves them to being very acceptable, and well worth the effort and junkbox parts.
Eric.
In A Nutshell
Hi Graham,
I have been using a program called RMAA, which is a stereo audio testing program.
In FR test mode, I feed soundcard line out into an amplifier.
The Active output of the amp drives the tweeter (woofer, box) under test, and 10 ohms to ground.
The other channel is two 10 ohms in series.
Soundcard line in is connected to the junction of the tweeter/10 ohms one channel, and the junction of the two resistors the other channel.
By applying the FR test, the driver under test can be compared to the reference 10 ohms resistor on the other channel.
This gives an upsidedown graph, but no matter.In A Nutshell
So far, this has worked well enough for me, and the acoustic results good.
Sorry that is all the time for now - I'll be back later tonight.
Regards, Eric.
Circlotron said:
Doesn't it make the drivers appear resistive to the crossover instead of all-over-the-place reactive?
mrfeedback, if you could post some of your results I would be very interested because I have been toying with the idea myself.
maybe both 😉
I'dl like to know more about RC and RLC networks, in what cases are they necessary, how they affect the sound, if they affect the XO frequency...
SY said:
Yes, absolutely. The drivers are being fed by a strongly reactive source (the xover), unless they're directly connected to the amplifier.
Sy is correct in that a crossover that has been optimised for non compensated drivers will need tweaking to bring the overall response back to correct.
I say that this ought to provide a smoother and nicer sonic result than using non-compensated drivers, and this is my experience.
Eric.
Directly across the driver connection terminals.
Good...that's where these should be.
Ever tried an outboard x-over?
Some speakers respond well to that kind of mod, others need some x-over tweaking but all in all you gain in clarity since the components aren't rattled by the drivers anymore.
Cheers,😉
