im new to repairing guitar amps
Does the circuit board have 4 stiff wires coming off it where there may have been a molex connector? Or were the reverb wires soldered in to board itself? I am assuming there are no RCA/phono plugs used.
Can you post a picture?
Mark
Had a look at a pretty small schematic online. the ''output'' to the reverb tank is marked J8 and the signal ground J? I could not read but it is across a 10 K to the signal out.
Return Back from the tank marked J13 on signal and J 14 on the signal ground.
