The switches I’ve found so far are only suitable for panels 10mm thick - I presume this means that the threaded barrel is only slightly longer than 10mm. My front panel is 13mm thick. Is anyone aware of an illuminated latch switch that has a long enough threaded barrel for this depth?
I was wondering what acne had to do with it, but google has enlightened me 🙄. Thanks, I think you are probably right.You might need a spot face on the back of the panel. Just a few minutes for most any machinist.
Electronic Surplus in Mentor OH buys an enormous quantity of EOL, over-runs and other:
https://www.electronicsurplus.com/switches/illuminated-switch
