Il Penitente amp kit packages
Official Court Jester
Joined 2003
Presenting thread here: https://www.diyaudio.com/community/threads/il-penitente.382007/
Schematic and pcb screenshot post #1 , plenty of pictures after .
Tips and Tricks thread - will open, sooner or later (if needed)
Reading entire thread is advisable , same as inquiring any technical question there : Be sure that you are aware of all things electrical and mechanical !
Pcbs are made for UMS , mounting directly to heatsink
Do not hurry - read , think , ask and only when you feel that you want it and can make it , proceed ...... advice which I'm finding applicable on practically anything .
For anything else , write either here , send PM or directly to >zenmodiyaudio@gmail.com<
Prices are mostly dictated with small scale nature of operation (as always is case) and time/work involved in matching and soldering little buggers.
For ordering , contact me at above written e-mail addy .
Kit options :
Option 1.
  • LCH pcb ,
  • RCH pcb ,
  • all smd buffer JFets (Toshiba 2SK2145BL) presoldered ,
  • smd precision CCS chips presoldered
  • all smd caps and resistors presoldered ,
  • 4pcs of 1uF MKC caps (for important bypass positions) enclosed.
Full price , including Paypal fee and P&P for registered shipping all around the Globe - 135E
Option 2.
  • LCH pcb ,
  • RCH pcb ,
-all multiturn trimpots
-IRF510/9510 drivers
-cascode bjts
-optocouplers
-all electrolytic caps (all Panasonic/whatever Brand name I lay hands on , Elna Silmic II for one signal route position)
-1 pins for few test points
- jumper pins and jumpers, in between buffer and autoformer
-all (MF 600mW) resistors
- rail resistors (0R22/2W)
-T0220 heatsinks - 4pcs
-NO BJT OUTPUTS - ZM being lazy to get those in quantity
-etc.
to recapitulate - everything what goes on pcbs , excluding signal xformers, BJT outputs and pcb/outputs mounting screws/nuts/washers ;
Full price , including Paypal fee and P&P for registered shipping all around the Globe - 185E
If I have everything in drawers in moment of order , can ship in a week time;
If I don't have any of normal parts in drawer , shipping could be delayed up to 3 days;
If I don't have pcbs in drawer , shipping could be delayed up to 2 weeks;
If I don't have most critical part for getting in my neck of wood - CCS precision chips , shipping could be delayed up to 3 weeks.
All in all - you all know that ZM is slow, but inevitable
Handy Addendum (in short : HA!):
-Cap Bank pcbs - set of 2pcs; dual rail, CRC (pads, if you want differential/whatever fancy you type of CLC), snap-in up to 35mm Dia, resistor and pads for LED, position for 10mm NTC connecting Audio GND to chassis;
-NTC pcb/ FW style Soft Start - set of 2pcs; each having place for 2 independent NTCs;depending of arrangement of primaries of Donuts you're using, you'll need either one pcb for two Donuts, or one pcb per Donut
HA! set is 25E more
see pics for HA!; lazy to search do I have photo of NTC pcb, but who cares
