If you would, please, tell me how to remove the pop-up 45rpm spindle on a Rek-O-Kut Rontine turntable? I want to play with mats and it kind of sticks up and gets in the way.
Responses that tell me that I shouldn't do what I want to do will discreetly be ignored. Thank you kindly.
If you Google, it talks about sliding the locking pin by tapping with a small nail then removing it with needle nose pliers. You then lift the adapter out. You may need to add penetrating oil before hand for possible corrosion.
