Anyone know idle power consumption of the various class D modules?
The only number I've seen is for this one
http://www.ebay.com/itm/2pcs-L20D-I...ltDomain_0&hash=item2c5dafb004#ht_7538wt_1258
"Total Idle Power Consumption 7W No input signal".
Doesn't sound like much but it adds up with 14 ch.
Most Class-D modules in the "hundreds of watts" power range draw similar power with no signal. If you climb in output power (hence supply voltage) this usually gets significant, specially when you want several channels in the same enclosure (hot, hot!)
Our sonora modules have low power consumption. For the S250 (250w/4ohm) it is 5W approx, good but nothing too special. But the S750 (750W/4ohm) also draws around 5W, three times less than some of our competitors.
Note that we are talking about no signal power consumtion, no "stand-by" power consumption (we go to half of that numbers in this case)
So for a given module is it correct that idle consumption increases poroportionally to the square of the rail voltage?
No. It would entirely depend on the construction of the module. Many modules have no input sensing that completely shuts down the output when no input is detected.
Many low power modules have idle consumption in the sub 1W domain even without such shutdown.
Not exactly, but close. There are some parts of the loss which are constant, some are proportional to V, and some are proportional to V^2.
7W seems about normal.
I have measured a few I have using a steplight power meter:
Appliance Power Meter – Find Your Energy Guzzlers Steplight: sustainability programs and education
(and previously a less accurate unit).
hifimediy T2 measures 7.5W idle
connexelectronics TA3020v3c measures about 13W
YuanJing TDA8920 measured 5W idle, but the Connexelctronics TDA8920 measured 0W idle on the older less accurate unit I had... which is probably actually 2 or 3W.
All of these using linear power supplies.
Depending on the construction. Usually depends more or less linearly on supply voltage. Our S750 has internal switching psu's for the aux voltages so dissipation is almost constant within the entire supply range.
I have a Icepower 1200AS2 as sub amp and it measures 35 watts idle, which is exactly as specified in the datasheet.
The idle power consumption can be found in the datasheets of the various modules.
Wow, talk about necromancing a thread.
I estimate the biggest losses during idle stems from the power supply, consumption from the amplifier itself would be very low in most cases.
- Class D
- Idle power consumption
