Identify this capacitor?
Can anyone out there identify these power capacitors?
If it wasn't clear enough - the capacitor colours are metallic red and grey-white.
Markings on the capacitor are as follows -
on one side:
'Elna' (brand obviously)
'(M)' (??)
'16V/2200uF' (rating obviously)
and on the other side:
'CE105C' (temp rating I believe)
'9722' or '9714' (batch numbers perhaps?)
'S' (S is within a circle)
Anyone?
on one side:
'(M)' (??)
Anyone?
M appears to signify A tolerance of +-20%
Not sure about the 'S' though.
The Elna website is quite thorough but I'm sure that you have already looked there.
A useful guide to cap markings is at the bottom of this page:
http://www.elna.co.jp/en/ct/pdf/al_caue.pdf
Is this Elna's standard range? I've only ever used cerafines or Silmics myself but I like the pretty colours on these.😀
Apex Jr said:
Electrolytic Radial Caps
M is + or - 20%
9722 and 9741 are date codes=
22nd week of 1997 and 41st week of 1997
CE 105C Degrees CE is Canadian UL
Stumped on the circle S
Steve @ Apex Jr.
Thanks for your reply! These caps are ancient. I will not feel bad replacing them.
Leolabs said:
They can be seen on some motherboards.
I have since replaced them with Panasonic FCs and FMs - now at least I know that that was not a bad decision.
Damon, my experience with electrolytics in general has led me to err on the side of caution. In contrast to you, I've seen caps in old tube testers go dry in just 30 years too! 🙂
