Hey guys,I'm looking for ideas for a small sub to build with a pair of 8-inch drivers.
I was thinking maybe something isobaric.Or something for the car,or a powered sub(s) for the living room.. I dunno,and don't really care,I got the drivers cheap ($5 each) a while back,and figured I'd finally try to put them to use somehow,they sounded pretty good in some small boxes I fudged them into after I got them,just for a test.
Maybe one of those cheap dual bandpass plexi car boxes would work okay?
Any suggestions for a box design would be great. 😉
Here's what I know about the speakers..(what it says on the rear.)
Linear Series (anyone ever heard of these?)
4 ohms 140W max
Fs: 50hz
SPL:87dB
QTS: 626
Vas: 1.28
Model LSW084
"optimized for small sealed box and 1 to 1 ratio small bandpass enclosures"
4 ohms 140W max
Fs: 50hz
SPL:87dB
QTS: 626
Vas: 1.28
Model LSW084
Your drivers aren't suitable for subs. A sub generally operates in the bandwidth from about 20Hz to 80 Hz; your drivers,with an fs of 50 Hz, aren't capable of going low enough.
For the house, surely. For the car, you might just lose the bottom of the bottom end. I would think if you put it in a biggish sealed enclosure in a small car, it -may- be passing fair or better.
You could do a 80 liters ported box, but the most you can get is to tune it at 40 Hz to be flat in room to 35 Hz.
Yea,I don't expect much low freq output from these little 8-inch guys,but I figured I'd give them a go,since they've been sitting around collecting dust. They sounded pretty decent in some random 8-inch boxes I stuck them into to listen to them..seemed to have decent low end response,for an 8-inch..
Might an isobaric/k setup would help lower the resonance?
Maybe something for a PC setup?
I've got the itch,and these are sitting here,i'm ready to go,just need ideas.
I just had another thought,I could use some woofers in the car,if they'll fit in the rear deck (I'll have to cut holes.) I dunno if it's wide enough.
I've already got a set of mid/midbass drivers,and tweeters,and a sub.
Any suggestions for a crossover freq for these?
