ideas for speaker baffle treatment? cork?
Hi Brad,
I've always used 1/4", medium weight, closed cell foam rubber. It's easy to work with, easy to attach, and readily available (in urban areas). It does a good job above about 1kHz.
Heavy felt (1/4") would be better, but it's a bit tougher to work with and very difficult to find. You could dye it to meet you esthetic requirements and I would expect it to damp well down to possibly 500Hz or so.
Rodd Yamashita
i have use open cell foam but since we get it only in white here i cover it with a black cotton cloth. the cotton cloth is not very thick very thin in fact aslmost tranlucent but it covers the foam well.
i have alos used felt but sincethe colour i got cheap was red i had it dyed. once could always srpay paint it.
Felt is the classic. For an all-out design, layers of different thickness and density can provide hours of experimental fun.
If you're going to use foam rubber or plastic, open cell is much more effective. Again, a multilayer system can be quite effective; one set of speakers I built used three densities, with 8 pcf at the bottom, going to 6 pcf, and 4 pcf at the surface.
I have used cork several occasions when I simply didn’t want to make router templates for recessing odd shaped driver frames. Cork sheet is readily available, comes in a variety of gauges and is very easy to cut.
If you are careful, the driver can be used as a template for cutting the cork. If the cut is tight enough to the frame edge (cork in sheet form is somewhat elastic), the cork will make a very snug and flush fit with the driver.
Unfortunately, thicker cork sheet does not bend easily. If you want to follow a baffle edge radius, make sure the radius is sufficiently large. I have not tried to trim it with a router, but I suspect that unless the bit was new routing it may tear it up.
I got the idea to use cork as a baffle veneer from looking at one of Be Yamamura’s loudspeakers at CES a number of years ago. Yamamura claims that cork sounds better than other materials, because it is natural and inherently well damped. While I have no specific insight into that claim, I did find the the finished speaker I built did sound very good, but really can’t say how much, if any, cork contributed to the overall sound.
Cork does look a little like particle board, but has a much nicer color. I have found that if it is applied and detailed correctly, it can look rather elegant.
NO BAFFLING.
Hello,
If you really want to cancel all frontpanel baffling:
Design for dedicated housing of you units a la B&W Nautilus.
If that's not feasable stick a sorbothane sheet on the frontpanel making sure you only leave the membrane/piston unimpeded.
This elastomer was used by the military to camouflage aircraft and submarine from radar/sonar signals.
Doing so will give a a near perfect point source.
It can also be put to good effect on the inside of the speakercabinet where it will effectively cancel resonance especially when used asymmetrically.(which I always do regardless of damping material)
My:2c:
Felt works well. The sample in the picture was salvaged from a set of 20 year old Marsland speakers.
I figure that if i stiffen the backside with glue i can use it for a grill frame.
I also have all the raw material to make my own felt and was going to experiment with moulding it.
dave
Sy,
I don't know why, but I never thought to look in the Mac-Car catalog for felt, I should have known.
There's a foam rubber store 2 miles from me. They carry anything from neoprene to bass foam rubber you can almost see through.
Rodd Yamashita
Sy,
I’ve actually had a lot of experience with McMaster-Carr at previous jobs. Although at home, I seem to have a mental block against them. I think their always fast delivery goes against my tendency toward procrastination.
Rodd Yamashita
Touche! Dave,
my prsent speakers baffle should be ready tomorrow. maybe i can send some photos to you again?
the baffle is 35mm thick and with a hadn saw took me 2 days to cut. i actually cut the baffle into 2 parts to makeit easier to handle.
meanwhile i am getting the hang of fiberglass resin and how to handle it. once that is dont i will linethe box with fiberglass and open cell foam.
