I have a Sony receiver with Dolby digital. I was considering removing the power amp, cleaning up the power supply, and building in 5+1 channels of zen balanced line stage, or something similar. Has anyone here tried something like this? Is this idea even worth considering? Seems like it could work. Then I would just build a decent 5 channel amp to go with it. Any thoughts on this idea?
This sounds like a good idea!
If you feel like you could even replace the internal DACs, add a low jitter clock or add async reclocking to get even better results.
Should work out fine. I suspect you may find a lot of functions are integrated into one board, but you can always just cut the traces to the power-amp section if necessary and cram everything in.
Implementing the bal line stage internally means you can also omit all the input protection components without fear.
I think this decoder costs less than $100 US. Ive been thinking about this or one of a few similar devices marketed for desktop computing as the decoder for a similar project.
http://www.videologic.com/Products/Product.asp?Product=VL-60510
Here is a photo:
Tiroth,
I figured I would have to create some new take-off points on the boards, as integrated as everything is. Input protection may have to stay, as I plan to implement at least 1 or 2 input as "direct" , bypassing all the nasty Sony processing.
Da5id4Vz,
That's kind of neat... may be a better way to go.
_ns
Da5id4Vz,
_ns
- idea: Cheap Dolby Digital Receiver Conversion
