Has anybody seen the October issue of Stereophile? There's a letter in there from Charles Hansen to John Atkinson (editor) about the new National op-amps (sub 1ppm distortion claimed).
Charles has an intersting take on IC's - does anybody else share this view?
Charles, can you shar e your views on this subject?
I think it will make for an interesting discussion.
You might have to PM him in order to attract his attention.
I could imagine that he still prefers discrete designs. Being a skilled designer he might be able to do even better than the modern op-amps which are already quite close to the "wire with gain".
For the average DIYer modern op-amps might be the better and easier choice however.
Charles
Charles
phase_accurate said:You might have to PM him in order to attract his attention.
Charles
"Quite close to wire with gain?"
Then why they all sound so different???
Charles Hansen Ayre or Charles Hansen AudioXP ?
I found only this one on this forum:
http://www.diyaudio.com/forums/member.php?s=&action=getinfo&userid=6888
Do they really sound SOOOOO different ? 😉
And don't forget that wires do also all sound veeeeeeery different !😀
Charles
Charles
日本語
IIRC, it is in response to an article on very low THD parts from National, maybe the LME49810? Or what it one of the new op amps? Can't remember. The argument being that low THD is not the be all of sonic performance. He also was against ICs verses fully discrete because he can choose the best discrete component while an IC designer has to use what ever the process allows. I have a paper copy in my office but being on the road I can't reference it. Maybe someone can post a link? I remember there were some points that I didn't agree with but that could be because they are not fully clarified in a short article.
-SL
-SL
- IC's vs Discretes
