Not familiar with the 300ASC but I think this is the key (from p.26):
You simply connect the three "signal sense" connections in parallel with your three input connections. This assumes a balanced input though, for SE input you need to connect the "signal sense -" to "signal sense gnd" (see p.25).
If you just want SE input (and no balanced input) you just use the + input and tie GND and the cold (-) balanced input together on the RCA. If you want both connections wired (but not used at the same time), wire the RCA between + and G on the XLR and then have a small switch to tie - to G when the RCA input is used.
Hope this makes sense - I probably should have made a drawing 😀
/U.
Automatically standby and power on depending on the audio input:
Connect the signal sense input to the audio signal and pull the 5V trigger low. The amplifier will power on when audio is present and enter standby after 13 minutes without audio.
/U.
I'll give these a try today. Thanks. I just did not want to futz things up and let out the little white smoke.
