IC Power regulator
Greeting all,
new to the site and already I'm lovin' it. a great group of people with ton's of knowledge.
I have a panasonic SA-HT75 dvd THEATER system, the power regulator is shot, no 7.5vdc output, I need to find a replacement. It only has the following marks, "STK470-050A" can anyone please tell me what the replacement p/n would be, or any info on this IC would be helpful. Thanks in advance.
Hi sandmaniac,
I moved you to the Solid State thread since you are trying to repair this unit. You may get a better response here.
The part number STK470-050A is what you need to look for. Type the number into a Google search and look for a supplier. A spec sheet may help also, and that you can get at the same time.
-Chris
