I have an Ibanez T150S stereo acoustic guitar combo amp. I’m wondering if the amp in it is 4 ohm compatible. Ibanez will not disclose the make or model of the module and the amp is buried behind various things. I want to replace the stock 6 ohm speakers with 4 ohm ones. Hoping for help.
you will have more answers in the Instruments and Amps section.
You can either write to Ibanez directly or open the combo box and measure the hp. I have an Ibanez 1987 electric guitar made in Japan, I changed the pickups.
The module is 7-1/8” x 3-5/8”
80 watts channel into 6 ohms
Hoping to identify the module and if it can drive a 4 ohm load
- Class D
- Ibanez T150S
