I would like to convert 4 I2S channels to AES outputs. I have googled a lot and either searching on the wrong thing or not understanding that I have found the answer.... What is a good method/chip/product to accomplish the task?
If you want a chip, check the AKM AK4101A.
Whats wrong with a couple of CS8406 and two pulse transformers?
A couple of CS8406, that's fine for 2 I2S lines, not 4.
The AKM AK4101A looks like what I want. I looked at the data sheet, but couldn't find an example circuit. Where should I look for that? Is the opposite chip available (4 channel AES to I2S)?
I thought I was going to need the 'opposite' chip to test, but I don't think I do now..
I still need to find an example circuit. I am trying to output 4 stereo AES outputs from a miniDSP SHARC.
