HI,Guys.
I just bought 2 PCM63PKs😀 ..like very much.
And i am designing a serve PCB for CDM4/CDM3 using SAA7310 as its DSP.
As we know SAA7310 supports I2S for DAC or DF.
Is there some one can help to use PCM63 with SAA7310?
I do not like to build a DAC alone.😀
it looks very helpful!
And is it possible for TDA1540?which is 14BIT.maybe we can add SAA7000 to turn 16BIT into 14bit and SAA7030 as DF.😀
Try the simple logic first (3 chips) I made the big one with 8 chips(series to parallel conversion) and it sounds a little dissapointing after the first sounds i got from the simple 3 chip logic sheme.
Hi
tubee
do you mean use 1 chip 74HCU04 and 2 chips 74HC164 to make the logic?
as i know CD930 use that logic to connect SAA7310 with SM5840.
SM5813/DF1700 has the same input interface as SM5840.
thank all above guys.😀
tubee
tubee said:Try the simple logic first (3 chips) I made the big one with 8 chips(series to parallel conversion) and it sounds a little dissapointing after the first sounds i got from the simple 3 chip logic sheme.
Could you please post a drawing for the simple 3 logic chips scheme?
- Digital Source
- I2S interface to PCM63
