Hi all,
I got my hands on an old Creative I-TRIGUE 3200 (Model: MS0760A). It came with a problem on the right channel; no audio was coming out.
When putting it apart, I found that in fact there was audio coming out of the right channel. However, when I tilt it in a certain position, then the audio is gone.
Left channel works no matter what.
I'm sure there is a most likely some crack somewhere along the right RC jack connection, but I can't determine where. I've refilled solder in some of those nearby traces, but to no avail.
I, sent a request to creative about this product, but they said they got no support nor documentation for the product as it isn't sold anymore. (I knew it was a long shot)
I was wondering if anyone:
They are also biased at approximately 6.2V, which seems reasonable since the input voltage is ~12V.
Thanks in advance
- Run into this same problem and solved it?
- Propose a way to solve this problem?
- Has reverse engineered the schematics for this product's board and doesn't mind sharing it so that I can guide myself on the signal path.
Thanks in advance
