I need some fairly specific capacitors types, like polyester or silva mica.
Normally this wouldn't be a problem, but I have some PCBs that dictate that I use axial capacitors in certain positions calling for a low value, the values being:
270pF (220 should do)
340pF (330 should do)
500pF (470 or 510 should do)
1000pF
4700pF
The 4700pF and 500pF need a voltage rating of 400v or more, whereas the rest can be rated at 125v or more.
I'm having great difficulty finding suitable parts that aren't ceramic or insanely expensive (£1 per cap?)
Does anyone know where/if you can get these types at a reasonable price? NOS should be fine if I can buy a fairly large quantity.
if you're looking at NP0/C0G ceramic then they are superior on all measures to polyester, and if dielectric absorption is taken as a "audio quality" indicator they overlap with Silver Mica depending on manufacturer
polyproplylene is common and good, polystyrene would be most people's choice for RIAA filter
Ive successfully used ceramic 4.7 uf coupler caps instead of grainy sounding (from the distributor that way) tantalum electrolytic caps. The caveat is I had a 1.6 V signal, and I used 50V caps. They are non-linear, but less so over only 1/25th of the curve.
That said, mica caps are available, I think from tubesandmore.com AZ, although it might have been triodeelectronics.com IL. Antique radio parts houses specialize in these. There is another radio parts house in Canada, I haven't bought from them so I don't remember the url.
