I did something different
I'm not aware of anybody trying this, I may even be the first...
I have an active system, my DAC is four ASUS Essence STX II PCIe cards.
My wife bought a cat and called it Dac, so I bought a DAC upgrade because fair.
So I bought four LHY lithium Battery power supplies, each stereo pair for my subs, woofers, mids, and tweeters are now (almost entirely) electrically isolated from each other.
I'm aware that battery powered DAC's often are reported to be superior, but four on four DAC's? It MUST be four times as good...
Previously they shared the LPSU I use for the Digital Crossover PC.
The benefit wasn't what I would call a "veil lifter" -after you move the crossovers into the digital stage before the DAC's, overall clarity is (almost) no longer an issue- but the improvement was apparent, I blind tested my (begrudging) wife by asking her to describe what differences she felt she heard -if any-from the test track I found for her, and hers concurred with mine.
Dynamic range was more pronounced, (her words: "the bass was more up and down, but like, wavy you know?") but more interestingly, the relationship between bass and treble had become less of a tradeoff.
I have preamplifiers and integrated monoblocks -a setup I encourage, as it can give different tonal properties to the same level of output- and with by turning down my preamp and turning up the power amplification just that smidge, it was like when I was a kid and managed to get the antenna on the radio to that exact sweet spot during the song I liked, I have a small amount of control over colouring, attack, I can change the timbre, if only somewhat.
This usually had the impact of the bass appearing too strong or weak, whenever I tweaked the treble (or the bass) I would also find the bass (or the treble) would often call out for some similar tweak, but now, they were no longer enemies, the tweeters were as amicable with the subs as the woofers would be.
I feel like transparency is greater, but it's probably just be being excited that it worked at all.
Turning on (and off) a fully active system with monoblocks and Multiple separate LPSU's dedicated to various components is like following the Minuteman launch procedures, I have some total of 30 odd buttons and switches to press and flick -one multiple times, several now only on occasion- in a set sequence, many of those reading will find this to be a total turn off, some, however have piqued interests...
My wife has (gracefully) allowed me to commandeer the lounge room on Tuesday nights, after the baby has been put to bed, but while dinner is being made I have to:
Switch all four new BPSU's from off to on.
Check their battery level -which is obviously apparent- and decide if I want to charge them, and if so;
Flick the four charging switches, plus turn on the one attached to the dedicated power board for their four wallwort power packs.
Press the power button to a second power board attached to the PC, and some various LPSU's for the preamplifiers.
Press the PC power switch (which doesn't work that first time)
Turn on the tweeter power amps
Press the PC power switch (which turns off the first failed attempt)
Turn on the midrange amps.
Turn on the PC (which works this time)
Turn on the woofer amps.
Turn on the subwoofer amps.
I still manually set the PC because my Linux skills aren't good enough to automate the steps I like.
Run PAXoverRack, load the filter profile.
Run PaVuControl, do the -3db trick
Run Rhythmbox (I like it)
Eat dinner
Turn off the charging switches to the BPSU's, turn off the power board for the BPSU's plug packs.
If you're still reading, you may still be eligible to access some cash from the Australian NDIS scheme due to Autism.
TL😀R
But yeah, does anybody else here know anyone who's hooked up four BPSU's to four DAC's, or do I get to make up a name for it?
I want to call it the Bradley Configuration...
Reactions: stv
