HYPEX plate amps
Has anybody had experience with the Hypex plate amps. I'm specifically looking at the HS500 model to use with a Peerless XLS 12 inch. I understand it will be overkill but I want to eventually run two Peerless XLS drivers from the same amp. I understand the Peerless go down to 4 ohms at times so I guess two would touch 2 ohms.
