Hello,
I am planning on building a set of Proac Studio 100 clones. I cannot decide between using the Hypex Plate amplifiers or using the Hypex Modules. Which will be the better sound? The plate amps will offer many more options with the active crossover and will save much time in constructing two monoblocks. If the sound result will be equal or better with the plate amps will the AS2.100 do the trick or will I benefit from the higher powered PSC2.400?
Thanks!
Thanks!
